mathew.
what is the end goal of your project. i would assume that you need a network adjusted csv points file that you are bringing into another cad file?
i am not sure why you would require SD and angles for any type of topo return? unless you are adjusting this data in another software?
why no use TBC for the adjustment and csv export?
i hope i am not missing something here. but from the few posts i can make a couple comments.
if you drag a csv into TBC you will only get coordinates. if you drag the .job file you will get all the raw data asociated with the field work(typically angles, distances and vectors). from the home page you can then open the optical spreadsheet and this will show the measurements. you can go into the main settings "cog" and go to view/optical and select the desired output to been seen on the optical spreadsheet. the data you are after should be there, but unfortunately it will not show the point asociated with it, only the "name" of the observation. if you are really after these values maybe you can cut and past from here. i have never tried it. or there should be a way to export your desired values. you might have to make a stylesheet for it.
but typically one would adjust the network in tbc and then use an easily built in tbc exporter to create a csv you can use in cad.
hopefully this helps.
ian bissonnette
Sent: 01-21-2021 21:12
Subject: ASCII file generator error
I was still having issues with the older version of TA, though I used the online converter to update my .job files to the latest version and now the ASCII Generator works! So one problem solved.
I have done a bit of searching around but can't find a explanation on how to convert HA, VA and SD to VD and HD? Is there a simple enough process I can execute in excel?
Thanks so much!
Matthew Elsley
Sent: 01-21-2021 13:26
If that fails then ask the company you hired the total station off to convert the job file into a JXL file.
As for converting the data into VD and HD, I can't think of a Style Sheet that will give you the data in that format, so you would need to convert the data using a spreadsheet. There is a style sheet available called Comma delimited with HA,VA,SD,time,date. You could use the vertical angle and slope distance output by this style sheet to compute the vertical and horizontal distances. Here is a link to the style sheet:
https://trl.trimble.com/dscgi/ds.py/Get/File-720086/Comma%20delimited%20with%20HA,VA,SD,time,date.zip
Other style sheets can be found in the downloads section of the Trimble Access page:
https://geospatial.trimble.com/trimble-access
James McWha
Sent: 01-20-2021 19:01
Unfortunatley we don't have the TS anymore as it was hired. The guys pulled teh Job Files off as the main data source.
I'll install the pre 2017 version to see if that will work. Do you have a reccomendation on how to get VD and HD as an output?
Thanks!!!
Matthew Elsley
Sent: 01-20-2021 18:40
If you are using a C5 or M3 in the field then you won't want the latest TA office files. You would want the TA 2017.24 or earlier office files.
You also could try converting the Job file into a JXL on the Total Station. To do this from General Survey, go into Jobs, Import/Export, Export fixed format, Trimble JobXL. Or if you want to create a CSV file of the coordinates select the Comma Delimited option.
Most Style Sheets that can be run in ASCII File Generator can also be run in Trimble Access. If you copy the style sheet into Trimble Data\System Files, then it should be available for selection in Jobs, Import/Export, Export custom format.
James McWha
Sent: 01-20-2021 17:32
No Luck with that unfortunatley!
Matthew Elsley
Sent: 01-20-2021 16:04
Hi Matt,
Try installing the latest office software update for TA from this link and see if solves the issue
https://www.trimble.com/support_trl.aspx?Nav=Collection-84862
ramin rad
