Hopefully, someone can help with this;
I have been using codes and linework commands for quite awhile, but I've been using Survey Pro for the vast majority of time. I have an .FXL file that contains linework codes and feature definition codes already (and loaded properly on my TSC7).
I've now started implementing Access for my boundary and topo type work, though. Everything seems okay, but when I started adding to my groups for Measure Codes (i.e., 5x5, 4x5...) Access doesn't seem to like the way I've entered my codes. I've entered my codes like this:
132 B (132 is EP and B is Begin)132132 E (E is End)132 CLS (CLS is Close)…and so on.
When I try to take a shot using this method, Access has a window that pops up and says, "Error-
132 B does not contain any line features"
I've gone back to my .fxl and verified that it is properly input and it is. This is the same feature code file I've used for many years.
My assumption would be that the CAD toolbar is having some effect on my code input?
Ultimately, I don't care how Access deals with my codes/linework commands, though (at least I don't THINK I care). I process all my data using Civil 3d - which has worked perfectly for me for many years. I merely want my points to be measured the way I have them input, so I can export an ASCII file upon completion of fieldwork and import that directly into C3D.
MP (NV)
