Hey Michael,
The side shot code in TBC is set to 33. On your MH side shots the code in the file is set to 34.
To change this, select the appropriate unit, click next 3 times to get to the columns and field options. Scroll down to the first observation field, select the tab for Measurement Type and change the code to 34. This will import the side shots in the file.
![](https://higherlogicdownload.s3.amazonaws.com/TRIMBLE/MessageImages/fc644115bb0144bead2f9458e32ee8db.jpg)
Let me know if this resolves the issue or if you have any additional questions.
Regards,
Shane Lyons
Shane Lyons
Sent: 04-26-2021 13:28
Subject: GSI Import - Side Shots Dropped, Not Imported (keywords dini gsi dna03)
