Yep, had the same issue when upgrading to a newer Windows version a few months ago. My work laptop had a dell docking station, USB-C and TBC kept crashing. Unfortunate for me, I didn't realize it was the docking station for about a week and I really struggled, had to use my personal laptop when I could. The solution for me was very simple. Stop using the docking station. Docking stations are meant for convenience of office works, if you're running TBC, you're not a typical office worker. Programs this robust don't always work with things like docking stations. I was lucky enough on my Dell laptop that I had 1 displayport, 1 HDMI and 1 USB-C that accepted video. I was able to plug 3 cords into my laptop to run each monitor, it worked flawlessly. Having to plug in a few extra cables was far from the most adversity I faced in a day, so I forgot about my docking station and never looked back. Now 95% of my work is done on a desktop and I couldn't be happier, obviously not an option for those traveling around.
Adam Bower
Sent: 07-06-2021 13:56
Subject: Dell DisplayLink Dock Issues
My company got me a new laptop that uses the Dell DisplayLink USBc Dock. I got TBC installed, but it just hangs whenever I try to start a new project or open an existing project. If I unplug the dosk and just run off my laptop, it works just fine. Has anyone else run into this and do you know of a fix (besides getting a new dock).
Thanks,
Chris M. Davis
Lead Survey Tech
Christopher Davis
