Hi Alan,
Thanks for your responses,
Just to clarify,
I am currently producing the asbuilt cross sections on TBC. I wish to produce the data as shown on the pdf cross sections but in an excel format i.e. chainages/offsets/design elevation/asbuilt elevation.
Is there a way to produce an excel format of the data directly from tbc with the Site Construction Package?
Cheers
walt shin
Sent: 05-11-2021 05:43
Subject: Converting PDF Cross sections into Excel/Tabular Format
The cross section conversion is tied to the Site construction package I believe - however the import and sorting out of the data is all possible with your version - the flip I could have my data team do for you if you do the prep work - I can get them to give you a price to do that as a service for you if this is a one off or even if it is recurring
We can show you how to do the prep work if needed.
If you need help in Australia / NZ I have a guy in Brisbane that can also help you also - he is on your time zone and is a private model builder and works in highways / rail projects a lot
Let me know
