When importing Trimble DiNi *.DAT files into TBC v4.10(?) the time stamp was appended to the mark name in the "description" column. This was useful for my needs as I was exporting the adjusted file into MSExcel to report results - including time of observation.
I am now running TBC v5.6 and the time is no longer reported in the description column.
I can see the time stamp in the raw *.DAT file, so I can export it that way, and add it to the final adjusted level report. But is there some way of adding a 'time' column into the Level Editor Report (for later export) so I can export it just once with the adjusted values?
Thanks.
Brent George
