Hello, I am now also getting these types of message when importing point clouds from UAV type processing. It is hit and miss when i will get the error.
I posted today in the Threads of this community also, and as I noted, I will share an image of the error message when i can.
Clayton Bradshaw
Sent: 04-25-2022 03:08
Subject: Point Cloud Import Error
Hello Mike,
could you please try to answer these questions?
- What are your computer specs? Specifically, the CPU, GPU models, and the amount of RAM?
- Is your GPU driver up to date?
- What operating system do you run? Windows 10/Windows 11/Windows Server?
- Do you use TBC on your machine natively, or do you try to access it via a remote connection/virtual machine workflow?
Thomas Widmer
Sent: 03-24-2022 03:50
Mike O'Neill
