When I create an Alignment, at times i use a point to grab the coordinates and today i tried using a station offset to get coordinates. I notice this when I do the POB where once the coordinates are in the two cells (N,E). I have to manually move down a row for the next segment instruction. Once I do this, my POB coordinates are turned back to 0.000. There are times I can get it to stick when using points. When doing the station off I can not get the N,E to stick in the POB cell.
1) is there a trick to this or is this a bug?
Francisco Guerrero
