As Michael said. its best to have a line with the elevation you want/need. That elevated line will then be a node when referenced. if you reference a line with no elevation ( elevation as a ?), you will see a long vertical line in your corridor. You wont want that.
question is what point are you trying to get to. Could it not be done with an instruction?
Francisco Guerrero
Sent: 06-02-2021 07:20
Subject: CORRIDOR INSTRUCTION
If you have a 3D feature line you can edit your corridor. At the bottom of the edit area and just above the 'Referenced Surfaces" is a selection called "Referenced lines". Here you can add your 3D feature line by hitting the +/- key. Your reference line will now shop up as a Node in your Template editor and you can tie to it with the "Connect" type.
Michael Shipione
Sent: 06-01-2021 11:46
Is there a way to get a corridor instruction to go from your last instruction to catch a featured line ?
kyle Boracchia
