Frank,
After working through your PI data I believe your issue is coming from the PI that is added onto the PDF as shown below:
The alignment geometry checks great until this curve and then everything is off after it and the error compounds as you move down the alignment. I would verify this data is correct as I believe it is the cause of your issue.
Running the Alignment Geometry report can really help verifying your data when you hand enter alignments.
Let me know what you find out.
Shane Odenbach
Sent: 02-11-2021 15:07
Subject: Create Alignment By PI Issue!
Hey Frank,
I will take a look at this and see if I can reproduce the issue.
Shane
Shane Odenbach
Sent: 02-11-2021 05:11
I have seen a few time when entering an alignment by PI. It does not pick up the PC and PT correctly following the plan alignment report. I was recently creating an alignment and notice that a curve followed by another curve had a different bearing going into the second curve. This made the second curve's length extended by 10' I can go do the create alignment by segment which is not the option I want to use. Following the build of an alignment i need to generate some report that gives me coords by the PI stations. I am a HCSS user and we upload the alignments into our plans. The alignment looks fine in HCSS at the PC and PT of the curve where I am having issues. I tried entering a no curve instruction for the PC and error show ups saying curve not fit. Image below shows my alignment created by PI's and by segments. the By Segment is the correct alignment and the PI is incorrect. I am also attaching the alignment report.
Any ideas on how to fix this By PI or is this a bug??
Francisco Guerrero
