Hi Damon,
unfortunately you don't have many options here. I wonder that you actually can work in the same file at the same time. TBC is creating a lock file and if it finds one when you open the project it will ask you if you really want to open and if somebody else is actually working in that file then your TBC shouldn't be able to override the lock file and it will ask you to open the file in read only mode. That might be a result of the file sitting in a OneDrive folder, never tried that.
But there is no functionality for multiple users to work in the same file and TBC also unfortunately doesn't have a functionality like XRefs in Autocad. You can only import/export data. There is a VCL format under Export/Construction. That is meant to move data between projects. If you select some data for export as VCL it will automatically add all the dependencies into that file as well. I.e. if you select a corridor surface only, it will also export the alignments and all the data that was used to create that surface.
Your only option is to export the lines for your assistant as VCL, he imports them into an empty project, he is doing all the changes, and once he is done he exports them again as VCL, and you delete the old lines in your master file and you import his VCL. Or use DXF if it's just some linework.
Sent: 05-13-2021 09:02
Subject: Office Production -- Multiple Users on a design
I am working on a large residential earthwork project that has multiple different phases. I have an assistant/intern that works along side me doing simple line elevates, line join, and prints, etc.. The company that we work for has Microsoft One Drive to save these files to and are backed up. The main issue at hand that I am running into and that causes problems are: When I assign my assistant to elevating lines.. I will also be working in the same Trimble Files due to it being accessible to both of us on the Microsoft One Drive. SO... files end up saving over files and losing extensive amount of work. What are my options?
Thanks,
Damon Evans
Damon Evans
