Hey Tom,
Have you tried to run as administrator and see if you get the same result?
I'll send over to our TBC engineer that deals with installation and see what he thinks the issue could be.
Assuming you downloaded the exe from your network drive, could you go to the TBC homepage, select the download link and download the full install from the email that is sent. I'm courious if this has something to do with the exe coming from that the network drive.
I'll let you know what our engineer comes back with as well.
Regards,
Shane Lyons
Shane Lyons
Sent: 06-17-2021 04:56
Subject: TBC 5.50 install
Hi Shane,
I misspoke when I say we install to our server when in fact we install to our personal C drive. The error keeps mentioning the N drive path but I cannot change it so I think that may be part of the problem.
Tom Silicato
Sent: 06-16-2021 12:03
Hey Tom,
Is it possible to copy the full install from the network and run from your c drive?
While you can install from a network location it can cause issues in some cases. For this reason it is recommended to install from you local machine.
Make sure to run the cleanup utility as well before running the install.
Let me know if this resolves the issue.
Regards,
Shane Lyons
Shane Lyons
