Manuel,
I haven't seen any design drawings for your project, are you chasing something like on the attached screenshot?
Marian Plucinski
Sent: 04-08-2021 06:36
Subject: Modelling embankment layers
Hi Marian,
below a sketch of what I'm trying to achieve and attached the EG model in xml format. As I mentioned before it gets complicated when ramps and footpath come into action.
Really appreciate you helping.
Kindest Regards,
Manuel Roldan
Manuel Roldan
Sent: 04-07-2021 20:07
Manuel,
Do you have any design drawings that would show what you want to model? Also, Original Ground Surface could be useful.
Marian Plucinski
Sent: 04-06-2021 11:06
Good afternoon,
I've been asked to create a model for each layers(250mm vertical offset) of an embankment for machine control and wonder if anyone can help me as I'm really struggling to get it done. What would be the easiest way?
Attached dxf and ttm of the design
Thanks in advance.
Manuel Roldan
