Alan,
You're right, I don't think I've ever seen a standard corridor alignment which required the use of the chord bearing over the tangent bearing.
My use case is in recreating property boundaries. It's helpful when georeferencing a site using data that doesn't otherwise contain any control.
The worst-case scenario for this type of task is to receive the bare minimum amount of information on only a few pages of non-vectored PDF's, including basis-of-bearing, section monuments, and a property line which includes non-tangential curves.
My main thought is that TBC has so many survey tools and commands, but it doesn't quite have all the tools available to recreate select bearing-distance shapes without workarounds.
Tyler Lindsay
Sent: 02-12-2021 09:40
Subject: Enhancement Request: Chord Bearing option for alignment creation
Have you checked project settings as there are alternative input methods for alignments that you can select there.
Look under view - Alignment editor
If you have arcs to enter by that method you may find them easier to create using the linestring editor and then convert to an alignment.
I can't say that I have ever had to create alignments in any way other than Geometrical or PI based inputs - chord bearing if i got that I guess I would draw using a polyline and then fit the curves to the frame I suppose.
Would love to see the plan sheet where those are provided where the normal data is missing - is that a state dot job or a rail job - if a rail job then you can pick the spiral type Rail (chord) but the spiral is still entered as length and end radius.
Alan Sharp
alan.sharp@rockpilesolutions.com
Sent: 02-11-2021 14:46
It'd be helpful to have the option to define an alignment curve using a chord bearing input.
Tyler Lindsay
