Hi Steve,
The list of bug fixes in the release notes are only a sampling of all the bugs fixed. In some cases, the fix for a described bug might actually fix numerous commands - but the fix description only mentions the initial bug.
They are probably better about posting every enhancement - but I'm sure there are many small ones that get added w/o any fanfare.
In this case, I'm defining a "bug" as when the code is not doing what the dev team intended. So this snaps issue was a bug and they fixed it. Fixing bugs is a priority for the dev team. They want it to work how they intended it to work. And I do appreciate your "productivity issues" likely have a lot of "enhancements" by this definition.
So if you have a hit list of bugs, I would test them against new versions. If they are still there, I know the TBC managers would say to submit support tickets, but others might say to post your list of "still not fixed" bugs on the forums. I know your time is limited, so maybe posting and seeing what feedback others can give is a middle-ground.
Quan Mueller
Revenant Solutions - TML Development
Sent: 08-04-2021 15:45
Subject: Why does TBC pickup ZERO elev. from snaps?
My apologies, I haven't seen this in any of the change logs and this will be the first of many productivity issues I've had that have been actually addressed, hints my comment. The reason I haven't undated is there hasn't been anything in change logs that would increase my productivity, only seen posts about new issues that could do the opposite.
steve schuler
Sent: 08-03-2021 18:42
So it seems this issue wasn't ignored by the devs, it was actually addressed sometime between 5.20 and the current build.
OP just needs to update.
Matthew Judice
Sent: 08-03-2021 14:21
I can recreate it in 5.20.
I haven't got a 5.3 installation on my computer anymore.
But at least since 5.40.1 the input stops and asks what elevation you want to use if it the snap is on a segment with undefined elevation.
Sent: 08-02-2021 17:08
I am not able to recreate that, it works as expected for me (running 5.51). What version are you running?
Matthew Judice
Sent: 08-02-2021 17:02
Last capture ended short and of course theres no way to delete or upload when editing post. Heres the full clip
steve schuler
Sent: 08-02-2021 15:14
When I try this I'm getting undefined. Could you upload the file that showed the issue? Also, what running snaps do you have turned on?
Gary Lantaff
Sent: 07-26-2021 11:32
When snapping to a line with "?" (no elevation) an elev. of "0.00" is automatically set on created linestring vertices. WHY? This is yet another frustrating feature of TBC that make no sense, needlessly adds to a workflow and will undoubtedly be ignored by devs.
steve schuler
