I went thru the changes that are to be introduced in 5.70, but I have failed to find any mention of the matter I find most pressing when it comes to TBC development: bug fixes that render TBC un-useable in some workflows.
On my site alone, we have 8 Engineering Surveyors working exclusively on TBC, clocking-in in total easily 30-40 hrs of TBC time daily.
We are really invested in this software, and improvements are a must if we are to expand it's use to another users.
Some of the most pressing issues:
- Introduction of the CAD Grips massacred snaps and ease of selection. Snaps must be fixed.
- Selection time of the multi segment lines has to be improved.
- CAD Grips are not available when editing vertical alignments in the Profile View with VE. Ginormous error.
- Drafting. TBC is unable to plot text as text. Similarly it is unable to plot a solid hatch. Both are converted to dense lines with generate files sizes far greater than needed. (Same PDF after plotting can be 0.5MB from AutoCad and 20MB from TBC)
- Drafting. For ages now line thicknesses, colours, text/lines priorities and layers orders are not respected when plotting. It is impossible to force TBC to plot line A over line B.
- Why exporting DWG with 10,000 objects takes 0.5hrs?
- Why importing DWG or DXF with 100,000 elements takes 1 hr?
- Why can't I create a new controller (SCS900) from the ControllerManager?
- Why can't I use my own WMS as a Background Map?
- TRB export. Still doesn't work.
- Utilities module. Unable to export custom utilities to SiteVision / TRB
- Utilities module. Unable to snap to the pipes. Unable to export pipes to lines / surfaces
- Being forced to use 3rd party paid macros for the most basic functions.
- Convert to linesting / explode surface / chord line / explode IFC should be integral part of even the most basic licence
- Where is grouping for Surfaces or raster files?
- Still unable to draft in the Profile View / Cross Section view. Plane Manager is great. Let us use it to it's full potential!
- Recently introduced Dependent Points is still buggy. Why can't I use chainage "-1" m?
- Still unable to run some commands without selecting the object first e.g. EditDynaviewBoundaryCollection
- Why explode does not work with all object types?
- When will I be able to add/remove/edit custom panes in the Properties of the object? E.g. Geometry/12d Attributes/Point Information/Imported Files
Those are just few dramas from the top of my head, related to workflows that I use daily.. Other people, with different workflows are running into different dramas that are showstoppers.
Are any of them on TBC's Dev Team radar?
Marian
