I tested it with one of my Alignments and it was correct. But with yours it's wrong.
I used one of my macros to create the black horizontal lines and you can clearly see that the elevation of the orange offset line is wrong.
It's wrong in 5.52 and 5.60.1. It has something to do with that vertical parabola you are using, because before/after that one the offset elevation is correct. And the offset line hasn't a parabola anymore, only vertical arcs. Shrinking/extending a parabola to maintain the same elevation as the source line isn't trivial, if not impossible. The offset line should in those cases probably just use densely placed vertical spot heights instead of vertical arcs.
Something you should forward to your dealer as bug report.
