I am at a loss with this one. I am trying to export curb&gutter lines, collected from SX10 data with TBC automatic function, to an .JXL file to be imported into Trimble Locus geographical information system. However, when I open the exported JXL with Notepad, it is only 9kb in size, and it includes only the project definition info (coord. system. etc.), no lines whatsoever about the lineobjects that should be there. The export-function in TBC did show all 93 lines as selected.
What am I missing here? We have used the JXL before to Import tree location & feature data into Locus' registry&map, direct from Access field software or TBC. This is the first time for linework, but they should go into the export file, even if our code correspondence table in Locus could be defect to import them, should they not?
Ville Ronkanen
