I am just getting into vertical design. I have a simple alignment that I am using to make a vertical design. As with most designs, cross slope transitions begin and end at odd stations, so when placing starting and ending coordinate for a cross slope rule, how is it possible to place it exactly at the station required. I tried using the offset line method...by right clicking, selecting offset line method, selecting the alignment, typing in the station, then clicking in the vicinity of the line which the cross slope is tied to...but the cross slope rule plots off of the station for some reason. Is just a bad graphical representation? How can I find out exactly where my cross slope rules are applied? See attached screen shot where the rule should be at 114+00.
Thanks
matt fleischman
