I was with a coworker and they were showing where their corridor material was in a slope and they used a connect instruction to close that material. There is two sub materials and when they did connect for the second material, the top material was thrown off and lost its connect function. I ran thru their corridor to see if i could see what it was doing and could not see why it did not function right. for the time being, I made an offset from the top material and that fixed the problem we encountered. Is there any quicks to making this work beside my little test i have shown below?
below is an image of the area where the problem is. When we connect node 9 to 4, it slope-connects fine. When you connect 12 to 9. It throw the top material off projecting that material straight up to finish.
below is an image where I created a node offset 0.01' from node 9 which i did not add to any material. I then did a connect from 11 to 2 ( you can't really see in the image the number) works great.
Francisco Guerrero
