This is something that I would find great use of as well.
Sent: 06-26-2023 20:16
Subject: Access and roads
Hi Adrian, which which of Kåre's are you referring too - Slopes?
If so then I've also had a request for this from Pontus Hermansson so it seems this is common (in Sweden at least), it's on the enhancement list now, and I'll bump it up the list as we now have multiple requests :-)
Cheers
Rob Koot
Sent: 06-25-2023 23:10
Hello
I´m also in to this feature and all in to what Kåre have to say about it. It would been rely good to have in a lot of jobs that now coming in to our company.
adrian@carigon.se unknown
Sent: 04-06-2023 00:59
right, Marian so there is a way to do it via some additional software, thats good to hear, I suppose you can run this on the "feild computer"(?), I'll see if a dare have a look at that, Rob, I dont think its specialized at all, just regular work duties, and just regular software tools. Some tools are available in other software but not in Trimble/Access/Road and vice versa. My thinking is, if Access cant do a specific job in a "effecient way", why not open up for third party software and let user decide what software is controlling the hardware(?). I like many things about Access and hate some of it(most notabla the STL/ENDL crap...),
Cheers!
Kåre Jakobsson
Sent: 04-04-2023 22:06
It feels like this discussion has turned into a fairly specialised area, and building solutions for niche markets becomes rather challenging (we get many feature requests and only a finite number of people to work on them).
Back to the original topic of the Slopes request, I've been doing some further research, and this request did come through to me back in July 2021.
Unfortunately the discussion was a bit messy because there was confusion on my part because two different things were asked for at once. After figuring out there was a Slope request, and also a discussion about LandXML files. The LandXML problem was a slow loading issue, and we fixed the speed issue with this file in 2021.20. Unfortunately the conversation ended up focused on the slow LandXML file and the Slope request got lost along the way. Sorry about the request getting lost, and sorry for suggesting the distributor didn't pass it on, they did! We have logged this to our enhancement database, so we now have two requests for this from the same customer. Any advances on that? :-)
Like I mentioned earlier, this is on the list and next time we are working on features in this area we'll definitely consider adding this at the same time.
Rob Koot
Sent: 04-03-2023 23:17
Hi @Rob Koot ,
Many road authorities have requirements to report on a random (or grid) sample, with the results being and average + standard deviations.
Very often we have to collect the points and then run them thru TBC ANZToolbox Reports /or Excel custom reports.
Marian
Sent: 03-30-2023 12:11
Kare, as far as I'm aware this is the first time this one has been asked for too. Perhaps others manage this a different way.
Rob Koot
Sent: 03-29-2023 04:38
to make sense of that formula, this is what it looks like(this is the 2nd topmost layer/grade) in the "office software", but the same "rules" work on the field software & in real time, in Swedish but you get the general idea I hope,
Kåre Jakobsson
Sent: 03-29-2023 00:08
OK Rob, now that you menationed it, I did ask another Trimble tech a few weeks back if is there is any tolerances "on the fly" when doing the control/documentation measurements for the subgrades levels for roads, tighter tolerances the higher you get to finished surface, this is something that also is available on the "other equip", you can set/save your tolerances, usually 3 of them for "normal" road work here in Sweden and you see instantly if the "accumulated" sum of all measurements is within tolerances(basicaly you have to be withing +-30mm from teoretical level at the topmost/before asphalt, and according to formula below, not all laying on the + or minus side of teoretical level), surely this if something that is being practiced alsewhere in the world,(?)
formula:
s ≤ 15
x within 0 ± (14-0,40⋅s) mm
Gross error if │xi │> 30 mm
Cheers!
Kåre Jakobsson
Sent: 03-28-2023 11:40
One last question - what other information would you like to see during stakeout that you don't get today?
Rob Koot
Sent: 03-28-2023 11:36
Thanks you for your time making the request. I will definitely add this to the enhancement list (the extra info you added here adds to the story and helps). When we are working in this area we can look to add this too.
Just because we've not heard the request, doesn't mean it is not being asked for - some distributors are better at sharing requests than others - what some fail to realise is that unless they pass this on it cannot make it into the product, and if there are repeated requests for the same thing, then keep letting us know so that we know there are lots of requests for this.
Rob Koot
Sent: 03-28-2023 09:43
Ok, thanks Rob for taking your time with this, not saying you are wrong, but this is something that is needed more than once every second year, having been away from road work for a while and now back, almost instantly this came up, have used this slope angle with other equip(other software/hardware...I'd really like to see the Trimble instrument opened up to 3rd party software!) and I'd say its quite relevant(essemntial was the word from a coworke(that uses the "other equip")) for the road works type of job I do every now and then where I work(Sweden). As said I talked to a Trimble tech the other day, he'd also put in a request for this slope angle, and he told me others have asked for it aswell, so yeah I think its needed, but hey thats just me...,
I did load a trimmed version according to you're instructions, did work(albeit slow(a 10km roadstrip))
I see that you rmethod works, its just that you have to tap in and double check your slope every now and then, or have a list where the angle changes,
Cheers!
Kåre Jakobsson
Sent: 03-27-2023 21:05
Hi Kare, we've had one or two requests for displaying more design info during staking over the years, but no one has specifically asked for the slope - which is the reason we don't support this today. Now that we have configurable deltas, improving this becomes easier than it was in the past. But the question we always have to ask ourselves, is this the most important thing we should be improving in the software next? One request for this in ~20 years doesn't put this high up on the list unfortunately.
You said you wanted this for the asphalt crew when milling the road - for the odd occasion this is needed, what's wrong with my suggestion?
I'm not sure they average surveyor setting out roads would use this, feels to me like there are other more useful improvements we should be working on first.
Rob Koot
Sent: 03-24-2023 03:52
thanks Rob, are looking into those,
what I'm after is to be able to get a slope angle at any cross-section,
cross section view as the pic: the cut fill as usual and at the same time get the slope angle? is this possible?
Cheers!
Kåre Jakobsson
Sent: 03-23-2023 17:51
Kare - I'm not sure I would follow Marian's advice.
12da files are primarily used only in Australia and NZ. 12da files are not actually roads, they are just strings, there is no concept of a road in the 12da file. 12da customers like to pick 1 or 2 strings, and work with those strings, not the road. So I'm really not sure a 12da file will help you at all here.
My recommendation for working with Roads would be to use LandXML. We have a topic in the TA help describing the process to export a LandXML file from TBC: https://help.trimblegeospatial.com/TrimbleAccess/latest/en/LandXMLroad-export-from-TBC.htm
There was also a recent webex that covered TA Roads I would highly recommend: https://geospatialresources.trimble.com/webinar/get-the-most-from-your-trimble-access-roads-application-9mar2023.
Back to the original request, let me see if i understand you correctly, you want to review the slope of a road surface? If so then you can do this in Trimble Access Roads today. Make your road selectable, select the alignment and then tap Review, select a station then tap the Xsection button, a section of the xsection will now be highlighted, and the details including slope is displayed on the right. Select a different node, to see the slope of different elements.
Is this the information you were looking for?
Rob Koot
Sent: 03-23-2023 06:46
Ok, thanks Marian, will try that.
anyone else that is missing the slope angle in degrees when in section mode?? sort of a "basic" thing I think should be included(could exlude that STL ENDL mess and use either line or point measurement via buttons...how hard can that be to implement?), (?)
Cheers!
Kåre Jakobsson
Sent: 03-21-2023 14:02
By far the best format to export files to the road module in access is... 12da
TBC has 12da exporter in Construction Tab.
You can select lines / alignments / surfaces and export them as one file.
Marian
