Add ECEF coordinates
  • 1.  Add ECEF coordinates
    Posted 05-28-2020 07:57
    Hello greetings to all,
    I am new to the group and I would like to ask if it is possible to add and fix geocentric (ECEF) coordinates when a static point is being processed, in my TBC I only find the option to fix Global, grid and local, thanks.
    Greetings,
    Jairo
  • 2.  Re: Add ECEF coordinates
    Posted 06-01-2020 10:28
    Hi Jairo,
    I don't think there is an option to "fix" the ECEF coordinates in TBC. May I ask why you would need to operate on the ECEF coordinates? What is the workflow look like? Thank you.
    Rui
  • 3.  Re: Add ECEF coordinates
    Posted 06-01-2020 12:54
    Hi Rui,
    Generally I use the TBC to process static points, for this I must obtain the updated coordinates of the position weekly from the Sirgas page of the permanent stations (http://www.sirgas.org/es/sirgas-con-network/coordinates/weekly-positions/), these coordinates are presented in geocentric coordinate format and I must convert them to geographic or grid coordinates , to be able to add them to the TBC, for this reason I wanted to know if there was any option to enter them directly into the TBC, so as not to have to carry out such a conversion, thanks.
    Regards,
    Jairo
  • 4.  RE: Re: Add ECEF coordinates
    Posted 07-30-2024 08:14
    Hello Jairo,
    How are you doing? I found myself in the exact same situation in 2024.
    Did you find the solution or alternative to this?
    Thank you!
    Mauro Ferreira
  • 5.  Re: Add ECEF coordinates
    Posted 06-01-2020 13:10
    Hi Jairo,
    I guess the easiest way would be through a customized import via Import Format Editor. Data field definition does support ECEF XYZ. Create Point feature indeed doesn't support ECEF XYZ yet.
    Regards,
    Christian
  • 6.  RE: Re: Add ECEF coordinates
    Posted 02-28-2026 14:13
    Yes. Both the create survey and create cad points tool should have a dropdown for keying in ECEF.
    Zach Edwards
