Add elevation attribute to ground points
  • 1.  Add elevation attribute to ground points
    Posted 02-02-2024 07:37
    Hello!
    Is there a way that elevation is automatically input to a point attribute when extracted from a Point cloud?
    More exactly, when I extract points in TBC and make them 2D in cad, I want to have the point elevation as attribute in properties menu.
    I added attributes to points defined in Feature definition manager so when I extract points I can manually input the elevation but it s very time consuming and I am working on big areas it s not effective.
    Thanks in advance!
    Cristina Negrea
  • 2.  RE: Add elevation attribute to ground points
    Posted 11-21-2024 16:36
    Hello
    It's a great question! How to drop points based on elevation from a point cloud?
    Kristof
    muszynski krzysztof
