As part of my diploma thesis I need:
Adding your own antenna in Access 2024. The antenna was calibrated in an antenna measurement chamber and I have the data (ANTEX FILE).
How can I enter this antenna in Access myself? As far as I know, the data must be inserted into Antenna.ini. According to what scheme is this done?
It is a low budget antenna. A "Starf-GGG830-02" with an alleged phase center error of less than 20mm. The antenna only costs €28. I would like to prove that such an antenna is completely sufficient, especially in the hobby area (geocaching). I have currently integrated the antenna into Access with an ArdusimpleRTK2B board using a SAPOS correction signal. The integration was surprisingly easy.
Best regards
Marc
Marc Lieser
