i can make some comments, some overlap what others have said. we typically use the .job file but i am not sure if there would be a difference there.
-we make sure to always delete all data collector created coordinates. first select all points then use advanced select/tab that says something like apply to current selection/dropdown and select coordinate/without clicking anywhere else expand your imported file and there should be coordinates still highlighted there/right click and erase. this way there is no chance that these coordinates influence the adjustment made by tbc, no flags will show because of the shift and only raw observations will be used.
-sometimes but not always you might have to select all 'as staked points', when they are all highlighted, right click and 'convert as staked points'. then delete them in the as staked column. they will not shift with a base coordinate without this step, they will now be converted up with all the other points.
-delete any 'azimuth records'. these don't seem to shift either. in the view filter you can turn off all observations and then turn on only azimuth to see if you have any, or use the advanced select tool again.
once all these steps have been made then you should be able to 'office enter' a control point for your base station and this will shift everything as you have done in the past. like the previous comment mentions make sure you have an rtk vector to your first two total station setups or else tbc will have no starting point. (you can fudge these in and make it work, but the work flow is more complicated).
ian bissonnette
Sent: 08-25-2022 08:21
Subject: Adjusting combined RTK and TS data from one job/jxl file to post processed base coordinate using TBC?
I would do the static work in the same project as the others.
I've learned to remove ALL coordinates, drop the site calibration and re-import my grid control (CSV file) when I have even a moderately complex project. I've encountered similar problems when using multiple RTK rovers. Control quality grid coordinates shift to the GNSS reference station coordinate.
This problem has been tremendously hard to reproduce, but I think it involves the site calibration and multiple RTK rover files.
Dave Olander
