The question was posted in both forums.
See my answer here
It's possible to a certain degrees in WM, but still limited and cumbersome. I'm requesting grouping since 01/2022. But as you know, costumer service ............
If publishing from TBC, it'd naturally be good to then have the same groups/device filtering/selection available as on WM.
Sent: 01-09-2026 12:53
Subject: Assign Designs to Specific Data Collectors
At this time, WorksManager designs published through TBC go to all devices assigned to the project. However, in WM you can assign specific devices to the design in the window of time when it is publishing/converting.
Nelson Hays
