This has been an issue for our workflow for many versions of TBC. When we import and process with our .fxl file we can see all the attributes entered in the field on the point spreadsheet and the properties screen, BUT if any changes are made, or additional data is entered in the attribute fields in TBC that data will not show in the spreadsheet and will not export in a "custom" .csv (with attributes).
The properties will show the TBC added attributes, and the "Export Feature Attributes" will export the TBC added attributes. But not a custom csv export from the export tab. Is this a bug that just hasn't been fixed (for a long long time)?
I've attached three files:
"Drainage_Sewer" is a "custom" export from the export tab using the "Feature Attribute Export.ocexp" (delete .txt to use), one photo path saved in Access.
"Feature Attributes" is an export from the "export feature attritutes" command button, two additional photo path attributes added and saved in TBC.
Same points, no changes, but different photo path attributes.
Any help would be appreciated.
Andrew Haukaas
