I am curious as to the difference between automatic registration through Plane-based registration and Pairwise registration? The auto registration in Plane-based takes significantly longer to process than in Pairwise, so I often opt to do my registration in Pairwise even if I have the tzf files with my scan. It seems that the Plane-based option does a refinement each time, is it necessary to run a refinement after every registration or can the refinement be saved until the end when all scans are registered?
Paul Keays
