Hi Ben,
That's not been my experience in getting the image and associated world file out of TBC. The "Capture" Command has always worked fine for me, and I've never used a plot box, just oriented the screen to show what I wanted captured. What version TBC are you using?
Also note that since Siteworks v1.70 there is an option to manually georeference images directly within Siteworks. While not as simple as capturing an image right out of TBC, which is nice because that creates the world file, you can take a screenshot of your TBC screen using the Windows Snipping tool. Then import the image into Siteworks and then based on two common points between your measured/design points and/or model and the image reference the image and produce the world file. Siteworks user guide entry on this
Steve DiBenedetto
