Adam,
If you have blank or no objects in your TBC, it will not work, so you need to import some points or line works in TBC, and the background map should appear.
Eric Condemilicor
Sent: 06-28-2022 07:08
Subject: Background Map Function is Missing
Yep I have a state plan coordinate system selected.
Adam Bower
Sent: 06-28-2022 07:05
Do you have a coordinate system assigned to the project or have imported a site calibration file? One of those is required for the background maps to work.
Wayne Welshans
