my workflow has been to get correct level elevations computed. this can be in tbc, or other software proprietary to the level, or manually in excel. i played around with the tbc level module and for our purposes it was way clunky and not worth the effort. excel was a more powerful solution. either way i would choose to dump the data out of tbc because i am not certain of how tbc would handle the data from the level module. others might be more confident with how tbc handles these, and it can also be tested easily if you do the steps bellow to them and note the verticals before and afterwards:
once you have the correct elevations for the points, use the network adjustment tool in tbc. create control quality coordinates for all control points especially the ones with known horizontals and the leveled verticals. when you go to do the network adjust choose to hold the verticals on all those that have been leveled to and the horizontal on known horizontals. this will force tbc to hold those good verticals.
ian bissonnette
Sent: 08-13-2025 06:09
Subject: Best fit elevations over known or established control
Ok, so then you would just hold the "computed" elevations in TBC without holding them as BMs and calculate the differences in excel? Or, just hold each level run with BMs (as TBC would suggest) and do the adjustments and then see how they compare at the end in excel?
Sean Lahann, PLS
Phoenix, Arizona
Sent: 08-12-2025 16:03
Hey, I was just told this can be done in TBC. Needs to be brought into excel and manually calculated.
Elijah Voigt
Land-Tech Services LLC
New Jersey USA
Sent: 08-12-2025 11:21
I know it's been years at this point, but did you ever get a response or resolution on this question? I have a monitoring survey that I am trying to do the same thing, but there is only one BM that can be held.
Sean Lahann, PLS
Phoenix, Arizona
