thanks for taking time out to look at that.
the hunter was the start of my survey career. I was the young assistant for Travis on the other bridges going over the F3. and I assisted you once doing a level run for the control pillars under the push bridge you were working on. I also assisted Jason and Ryan from geometric.
Sent: 09-16-2024 20:16
Subject: bug - no join control code processing
Hi Peter,
I had a quick look during lunchtime. I do see the same behavior in 2023.11 and 2024.00. So, it's nothing new.
I do see your point though and would say it is a bug. Even though no line is supposed to be created it should at least relayer the points. But it seems to completely ignore the points once it sees the "don't join code". If you use the "start line" or "end line" code for each point it does relayer them, but of course you'll get one-point polygons.
You'll have to send this to UPG and they need to push it to Trimble. But the chances are high that this is considered a feature and not a bug and they most likely suggest that you use a specific point code for the ones you don't want as lines.
Sent: 09-16-2024 16:18
Hunter Express Way feels like a lifetime ago. Had to find my CV, which obviously hasn't been updated since 2019, and see that this was 2011/12.
I'm getting old. I'm racking my brain to place you.
I'll have a look tonight and try to replicate this.
Sent: 09-16-2024 15:46
Hey mate,
it's been a while since the Hunter expressway.
I'm currently running version 2024.1.
Peter Batson
Sent: 09-16-2024 14:29
Which version are you running?
There is a major feature code processing bug in 2024.00, with numeric codes and multi coding. I've heard rumors that it's been fixed in 2024.01, but it wasn't included in the release notes for that one.
