Can't open any new or old projects in New install of TBC 5.81
  • 1.  Can't open any new or old projects in New install of TBC 5.81
    Posted 12-15-2022 18:37
    Edited by Andrew Haukaas 12-15-2022 21:13
    (This issue has been solved. An up to date graphics driver solved the issue.)
    I've uninstalled and reinstalled several times using Cleanup between installs. I've tried everything I can think of and nothing seems to help, so please help...
    I'm hoping someone knows how to read this error log better than I can and can point me in a useful direction to correct whatever is causing the issue:
    (Inner Exception)
    (Inner Exception)
    (Inner Exception)
    Exception Count: 1
    Exception Source: Sde.NET
    Exception Type: System.AccessViolationException
    Exception Message: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
    Exception Target Site: sde_GetVideoMemory
  • 2.  RE: Can't open any new or old projects in New install of TBC 5.81
    Posted 12-16-2022 06:08
    Edited by Ben Brown 12-16-2022 06:12
    had this happen with 5.81 i believe it is a Citrex workspace issue as it only happened when i was using remote access from home in my case had to go back to 5.62 when working from home
    Ben Brown
  • 3.  RE: Can't open any new or old projects in New install of TBC 5.81
    Posted 01-04-2023 13:56
    Andrew, I am getting the same error since we moved offices, even the older version doesn't work. Have you found a solution to your issue?
    Paul Morales
  • 4.  RE: Can't open any new or old projects in New install of TBC 5.81
    Posted 01-04-2023 18:44
    For me it was solved when I updated my graphic drivers.
    Andrew Haukås
  • 5.  RE: Can't open any new or old projects in New install of TBC 5.81
    Posted 05-02-2023 23:43
    Same problem here, but driver update didn't work. Any other suggestions?
    Rick Gillesen
  • 6.  RE: Can't open any new or old projects in New install of TBC 5.81
    Posted 05-04-2023 02:08
    My go to if I see any read write access errors is to right click the launcher and hit run as administrator.
    Matthew Pitt
