Do you only have Trimble Access or do you also have TBC?
If all your data in a JOB file are observations, TA is using your first observation for the positional values to use in the field when you call up that point name.
In TBC, you'll need to use the network adjustment in order for it to use more than 1 type of observation for the position of points.
Robert Hoy
