Convert .t02 to RINEX
  • 1.  Convert .t02 to RINEX
    Posted 05-21-2024 12:59
    Edited by Chris C 04-13-2025 08:07
    I need to convert a Trimble t.02 file to RINEX files. These are for a PPK drone flight. This is not for OPUS or other GNSS processing. I need the actual associated .o .n and .g files. I found an old Convert To RINEX 3.1.4.0 utility on Trimble's website but it throws an error any time I try to open a .t02 file in it. The only other thing I see on Trimble's website is the GNSS processor, which doesn't give the RINEX file. Can this be done in Trimble Business Center or with any other Trimble or non-Trimble tools, either free or otherwise?
    Thanks.
    Edit: Solved. The problem was what UAS USGS mentioned below. I had installed Trimble Convert To Rinex but NOT Trimble Office Configuration Utility. You need both in order to get the software to run.
  • 2.  RE: Convert .t02 to RINEX
    Posted 05-21-2024 19:15
    You could try the Spectra Converter Spectra Geospatial.
    Those receivers are just rebranded Trimble SPS receivers as far as I know.
    And you can try TBC of course.
  • 3.  RE: Convert .t02 to RINEX
    Posted 05-22-2024 08:15
    we run that trimble 3.1.4.0 without any difficulty. what error are you getting, perhaps there is an issue with the file? also i don't see you mention what heads it is off of?
    ian bissonnette
  • 4.  RE: Convert .t02 to RINEX
    Posted 02-07-2025 07:36
    Not OP but I get the following message:
    System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.NullReferenceException: Object reference not set to an instance of an object.
       at trimble.rinex.CfileConversionInfo.get_antennaType()
    I ran Trimble Office Configuration Utility to get the latest antenna files but it doesn't help on Win10. Running as administrator doesn't change anything. Compatibility mode (Win7) doesn't help.
    I have a feeling it's a C:\ProgramData\Trimble access problem
    Karsten Maier
  • 5.  RE: Convert .t02 to RINEX
    Posted 02-08-2025 10:21
    @Karsten Maier  I believe this error is because you need to also install the "core" Trimble stuff for Convert to RINEX to run. I believe I just verified the problem will be resolved if you install the Trimble Office Configuration Utility
    https://tbcrelease.blob.core.windows.net/update/config/24.10.22/TrimbleCFGUpdate.exe
    3.1.4 is definitely the version you want. I found a bug in 3.1.5 while trying to convert my t02 files from my Trimble R2. But, if you want 3.1.5, here is a download:
    https://trl.trimble.com/docushare/dsweb/Get/Document-1073640/convertToRinexv3.15.0.msi
    The Convert To RINEX PDF is here which contains the download link:
    https://trl.trimble.com/docushare/dsweb/Get/Document-1051259/
    My copy of 3.1.5 threw the same error as you. I installed Trimble Office Configuration Utility and successfully opened and converted a T02 file.
    Joe Adams
    Denver, CO
    UAS USGS
  • 6.  RE: Convert .t02 to RINEX
    Posted 02-09-2025 03:01
    Edited by Karsten Maier 02-09-2025 03:02
    Thank you UAS USGS for the information.
    I wasted most of the Sunday trying to install TBC which I was told will fix my issue of missing dependencies. Turns out I couldn't install TBC because Coordinate System Manager didn't create the folder C:\ProgramData\Trimble\GeoData. The crazy part is that I'm on Win10 64 bit but it turns out only the 32 bit version (csm_3.10.1.0_x86) will work. Using the file csm_3.10.1.0_x64 will run the installation but the necessary folder won't be created. As soon as CSM was running properly the RINEX converter worked too. What a mess!
    "I found a bug in 3.1.5 " can you describe the bug you found? I'm also converting R2 data.
    Karsten Maier
  • 7.  RE: Convert .t02 to RINEX
    Posted 02-13-2025 09:47
    Sorry for delay Karsten.
    The bug is 3.1.5 does not populate the approximate xyz location in the RINEX file header. 3.1.4 does populate approximate xyz location in the RINEX header.
    UAS USGS
  • 8.  RE: Convert .t02 to RINEX
    Posted 07-09-2026 07:15
    I need the most up-to-date version of the Rinex converter; I can't find it anywhere on the web. If possible, please send me the link. I need this support.Thank you for your attention.
    mk gmail.com
  • 9.  RE: Convert .t02 to RINEX
    @Karsten Maier I am posting this a second time so sorry if a duplication. My first attempt at replying disappeared?
    I think you need to install the Trimble Office Configuration Utility along with Conver to RINEX.
    I reproduced your problem with CtR 3.1.5 and then successfully opened and converted a T02 file immediately after installing Trimble Office Configuration Utility.
    Here is a link to a PDF with a link to the latest version of Convert to RINEX:
    UAS USGS
  • 10.  RE: Convert .t02 to RINEX
    Posted 11-10-2025 06:37
    Excelent
    José Encina Añazco
  • 11.  RE: Convert .t02 to RINEX
    Posted 04-12-2025 11:20
    Hello, did you ever resolve this problem?
    Austin Spencer wand
  • 12.  RE: Convert .t02 to RINEX
    Posted 04-12-2025 12:02
    Hey Austin, OP here. Yes, the problem was what UAS USGS mentioned. I had installed Trimble Convert To Rinex but NOT Trimble Office Configuration Utility. I needed to install both in order to get Convert To Rinex to run.
    Chris C
