Corridor Design Not Publishing Correctly
  • 1.  Corridor Design Not Publishing Correctly
    Posted 05-06-2025 11:29
    I am trying to publish a design in TBC. Its a simple design, but when I publish it out to works manager, it is leaving out the node for the tie. See screenshot. It is just showing the start node, and two others. I don't understand why its leaving them out. But when I check the surface that is created from the corridor in the field it seems to be correct, and extends past the last node to the existing as it should.
    matt fleischman
