The use of another surface to create a corridor instruction. The new surface does not generate properly. As the new surface is trying to add new vertices/ if you can Explode the surface or import the surface, letting the import function explode the surface for you.
Francisco Guerrero
Sent: 08-30-2023 08:14
Subject: Corridor from Surface/Alignment
When you create a corridor and insert a template, use the Surface instruction to add an existing surface to the corridor.
Nelson Hays
