Hoping this may be of use to others as well, but I would love to see an Elevation option of "Surface" added to the corridor instruction options. For example, you create a new Offset/Elevation instruction, lets say your offset is 2m, and your elevation would be Surface instead of Elevation or Delta Elevation, or Node, etc.
Use case - you have 2 minimum constraints and one set constraint - 2m minimum wide ditch from road shoulder to backslope shoulder, 0.150m minimum v-ditch depth, and a set 4:1 foreslope and 4:1 backslope (silly conditions yes, but that's what's in the the plans I was given) and you check to make sure your ditch actually drains (we're for the contractor in this case, not the designer).
A more likely use case - you have your foreslope from road shoulder at say a 4:1 to your designed ditch elevation, 1-2m ditch bottom or v-ditch. When you get to the backslope, you're limited to how far out you can go due to a right-of-way limit or something and you don't particularly care if the backslope slope is consistent, you just want to grade it between the ditch bottom and the right-of way limit. The dreaded "varies".
Yes, I know you can elevate you're right-of-way or min/max limit line to whatever surface you want and then simply reference the line into the corridor. I just think this would be a nice little add that can alleviate a few extra steps/lines/layers, etc. Also helps to not have to change task when you're in the middle of trying to figure out the "ifs" and "else ifs" of conditional statements when you realize that that's what you need.
Anyway, back to my conditional statements in my corridor template...
Thanks!
Katie
Katie Byron
