I tried what you suggested. Afraid did not work out for me.
So, I am now trying another way. Please see attached file.
It is monotonous to build a template like this. I have gone down to FRL-1.78m now. I need to go till FRL-7.00m @ 20 cm intervals.
Wondering if there is an easier way.
And there are several roads like this !!!
Saif Bin Darwish
Sent: 05-31-2023 07:29
Subject: Corridor Template - Multiple Fill Layers
In TBC, you would have to build a new node and a slope/slope command to catch the side slopes for each layer.
In terms of constructibility, simply have the machine control operator run Lane Guidance for the desired grade on top, apply a vertical offset down to the desired level, and run a cross section view so they can see the side slope and not overbuild it.
Nelson Hays
