I need to create a 3D PDF file from my model and I have some problems.
The part of the model looks like this in TBC v2023.11:
As can be seen in the picture above, there are some descriptions of the objects and also the elevations of measured points along
with contours with their elevations.
I select to export all of the displayed elements (in fact, I select for export ALL) to create a 3D PDF file.
When I open the exported 3D PDF file in Adobe Acrobat (not Reader), I see the following:
As can be seen in the picture above, the descriptions of the objects are missing, the elevations of the points are missing
and also the elevation values of the contours are missing although I selected them for 3D PDF export.
Where is the problem?
Or, is it a TBC ´s export problem?
Thanks in advance to anybody for some tips how to get the required information into the 3D PDF file.
Martin Kalafut
