Hi David,
can you explain your workflow and deliverables in more detail?
Do you want to generate a raster TIFF which represents the terrain with an equal-spaced raster distance?
Do you want to create this deliverable from point clouds coming from aerial drone images, or aerial lidar, or terrestrial lidar?
Do you expect to allow a selection from specific classes (e.g. only ground points) for the creation of the DSM/DEM?
What is your definition of DEM or DSM?
Will you need it in 16bit or 32bit?
Shall all raster points be north-oriented?
Do the raster points need to start from an integer coordinate?
What about gaps in the raw data? Do you expect interpolation of the gaps? What interpolation type is accepted by the customer asking for it?
I know there are many questions, but we would need a specification and clear understanding what you are looking for.
Thomas Widmer
