You don't have to click in that field, you just have to have your cursor there. Generally in TBC if your cursor is in a field looking for a particular object type or parameter, you can then click on another object to extract that property or right click for contextual snaps and references.
So if you select a green CAD line and click in the 'color' property to highlight that field, then go click on a yellow line, it changes that property of your selected line to yellow.
If you're looking for elevation, in the sense your cursor is in that field, you can click on any object in the plan view and it uses that selected elevation. If you don't have a surface vertex point exactly where you want to use the surface elevation, then a right-click for surface snap can be used exactly at the location of the selected point.
Nelson Hays
Sent: 09-18-2024 05:48
Subject: Create Point- assign elevation based on where it falls within surface?
Thanks Nelson, I had no idea right clicking in fields gave the options for various commands, thought everything was shown as a button or drop down menu.
Christopher Partridge
Sent: 09-16-2024 10:40
When in the elevation field, right click for a From Surface Snap
Nelson Hays
