This is more of a enhancement request.
I work with our in house engineer who designs all of our structures in Revit and lately I have had him export out his models in ifc format and bring them into my site models. I really love this because it just give a better look and feel of the project as a whole and how everything fits together. The problem is when he is not the design engineer and I am creating models based off other engineers drawing I don't get these ifc files. I would like to be able to build solid objects in TBC such and retaining wall, MSE walls, Abutments, curb & gutter and even pipe. This would help build a more complete model where we can check for conflicts ahead of time. What we run into is that firms usually have multiple people design the projects and there seems to be a lack of checking the design against each other for conflicts. They push that onto the contractor to find the problems. For instance, the project I am working on now is a pedestrian bridge across a four lane hi-way and in the embankment behind the MSE wall there is a CIP retaining wall. The problem is that the PVC sleeves for the handrail posts are going through the footing of the retaining wall. now something has to be moved or the footing modified.
Now I have an idea for how a person could quickly build and shape and run it along a 3D stringline for control (or alignment for that matter). I think you could use the "create Side Slope" command to do this. That way you can build whatever shape you need as opposed to predefined shapes. As I understand it now you can do this same process using this command but TBC is unable to make the shape solid it is only a surface. A solid shape would allow you to check for volume as well.
Its just a thought!
Thanks, Ben
Ben Ryschon
