Creating Reports in Trimble Business Center
  • 1.  Creating Reports in Trimble Business Center
    Posted 06-05-2025 11:55
    Hello All,
    I am curious if you know any, or TBC has a way to create a spreadsheet with the following information. Station, Offset, Point Description, Point Elevation, surface elevation, and difference from a surface. I have figured out how to create point labels with this information. Currently I create point labels and then proceed to type it into a spreadsheet for an actual deliverable.  My ultimate goal is just to create a clean document showing the check sections taken before construction and comparing them to the cross sections. I am always open to new ideas!
    In Civil 3d, I could accomplish this with the Sinc Pac addon pretty easily.
    If it matters, I am collecting the data in Trimble Siteworks.
    Thanks in advance,
    Dave Martin
    David Martin
  • 2.  RE: Creating Reports in Trimble Business Center
    Posted 06-05-2025 12:42
    You can do this using the Siteworks Report Utility spreadsheet
    https://forms.trimble.com/globalTRLTAB.aspx?nav=Collection-126426
    Ed Levandoski
  • 3.  RE: Creating Reports in Trimble Business Center
    Posted 06-05-2025 13:08
    Ed,
    This definitely looks like an option moving forward. Is there a way to change a workorder to reference a surface after you have taken the shots? I can see everything except for the surface information. I made the surface after i got back to the office.
    Thanks for taking time to help!
    David Martin
  • 4.  RE: Creating Reports in Trimble Business Center
    Posted 06-06-2025 09:18
    Good Morning, David.
    I am not sure if this is what you are looking for, but by selecting Station Offset Elevation in Reports on the Corridor Tab, you can select the alignment, the points or the lines to be referenced along with the Surface.
    Hope this helps
    Ken Bork
    Ken Bork
