What would you want to use that surface for?
In TBC unfortunately you still can't create complicate solid IFC type objects. (ANZ-Toolbox soon will have some basic extruding functionality, we saw a demo).
But even then forget about creating models like that
TBC can import them, but is probably a long time away from actually being able to create them. Which is surprising since Trimble owns Sketchup. And with that you have amazing snap, extrude and body intersect/combine functionality.
A TBC, Trimble Access, Siteworks (and I believe also any third party) earthworks surface can't have exact vertical faces, vertices exact vertically above each other or triangles vertically above each other.
Or put differently, in Z-direction (or projection direction for projected surfaces) a ray, parallel to that direction, must not hit more than 1 entity (vertex/triangle).
