Cross-section plots
  • 1.  Cross-section plots
    Posted 07-17-2022 20:31
    Hi all
    I'm new to creating cross-sections in TBC.  I've got myself an alignment, corridor and a couple of surfaces I want to compare against each other.
    I'm trying to fit 3 sections on a sheet, which should fit if the vertical range is reduced.  How do I set the vertical range of the section displayed please?  You'll see in the image below the range is from zero to -46m (it shows seafloor) but I want the vertical range to start at -22 instead of zero.  Please note I'm not talking about vertical exaggeration.
    Thanks for the help.
    Bevan
    Bevan Waller
  • 2.  RE: Cross-section plots
    Posted 06-27-2025 10:23
    Bevan, I just noticed this post and was wondering how you got the custom title block. Right now all I use are the stock ones that came with TBC.
    Thanks, Matt
    matt fleischman
  • 3.  RE: Cross-section plots
    Posted 06-27-2025 11:32
    @matt fleischman
    https://community.myrockpile.com/t/drafting-how-to-plot-a-perfect-11x17-sheet/510
    Erik Petersen
