CUDA error with RTX 5000 series when training custom DL model in TBC
  • 1.  CUDA error with RTX 5000 series when training custom DL model in TBC
    Posted 12-24-2025 08:45
    Hi everyone,
    I'm running into a CUDA runtime error when using the custom DL model training to train the demo stockpile dataset.
    And I'm trying to find out whether this is a GPU compatibility issue or if there is a supported workaround.
    My error (read from log file):
    RuntimeError: CUDA error: no kernel image is available for execution on the device
    CUDA kernel errors might be asynchronously reported at some other API call, so the stacktrace below might be incorrect.
    For debugging consider passing CUDA_LAUNCH_BLOCKING=1
    Compile with `TORCH_USE_CUDA_DSA` to enable device-side assertions.
    CUDA compiler:
    nvcc: NVIDIA (R) Cuda compiler driver
    Release: CUDA 13.0, V13.0.88
    GPU: Dual NVIDIA RTX 5070 Ti
    OS: Windows 10 Pro
    Hoang Bach Cao
  • 2.  RE: CUDA error with RTX 5000 series when training custom DL model in TBC
    Posted 12-30-2025 04:49
    Hi Hoang Bach,
    Thank you for your comment. The developer will investigate this issue.
    Regards,
    Evelina
    Evelina Indilaite-Gale
  • 3.  RE: CUDA error with RTX 5000 series when training custom DL model in TBC
    Posted 12-31-2025 08:08
    I have exact same issue on Dell Precision Pro Max 16 laptop with NVIDIA RTX5000 GPU!!
    Dennis Belgrado
