Curves not drawing through all points between PC & PT point
  • 1.  Curves not drawing through all points between PC & PT point
    Posted 01-19-2024 07:51
      |   view attached
    We are having an odd issue with how curves are drawing in our TSC5 data collectors.
    The curves drawn in the data collector do not draw completely between the PC and the PT (see attached screenshot).
    Two of our field guys have different things showing up when they shoot the same codes in the same order with the same FXL file. One of them has a continuous curve going from the PC to the PT point, and the other has a situation like this where the curve only shows up on the first and last segment.
    In the FXL we use, the PC and PT are defined as 'Starts a tangential arc' & 'Ends a tangential arc'.
    The screenshot is from my Access on Windows where I was testing the behavior of the arcs.
    Is there a setting that needs to be changed on the collector or is this caused by another issue?
    VS-DW gmail.com
  • 2.  RE: Curves not drawing through all points between PC & PT point
    Posted 01-22-2024 09:51
    Those arent tangential arcs though, are they? Try using start and end Smooth Curve instead?
    Michael Fletcher
