Custom .py macros not appearing in TBC (even minimal test macro)
  • 1.  Custom .py macros not appearing in TBC (even minimal test macro)
    Posted 04-22-2026 19:50
    Hi everyone,
    I'm on TBC 2025.21 with a full Survey Advanced license. No custom macros (including the tiny TestMacro.py below) are appearing in the F12 All Commands pane.
    I have:
    • Placed the .py file(s) directly in C:\ProgramData\Trimble\MacroCommands3\
    • Given "Users" Full Control permissions on the folder
    • Deleted MacroCommands3.dict multiple times
    • Restarted TBC
    • Run "Set Ribbon Tabs → Reset to Defaults"
    AllTerra NZ support also tried the macro on their end and couldn't get it to load either. They suggested posting here.
    Test macro I tried (doesn't appear):
    import clr
    for asm in ['Trimble.Vce.Core']:
        try: clr.AddReference(asm)
        except: pass
    from Trimble.Vce.Core import *
    class TestMacro:
        def __init__(self, project): self.currentProject = project
        def Execute(self):
            print("✅ TEST MACRO RAN SUCCESSFULLY!")
            Client.ShowMessage("Test macro worked!", "Success")
    def CreateCommand(project):
        return TestMacro(project)
    I'm trying to achieve a very simple task: loop through all Total Station observations and write the Azimuth (degrees) and Horizontal Distance as User Attributes on the foresight point.
    Would really appreciate any help. Thanks!
    Mainland Surveying
