Cut Fill labels not printing correctly - transparency issue
  • 1.  Cut Fill labels not printing correctly - transparency issue
    Posted 01-17-2024 16:55
    Hi
    I am having issues with the Cut/Fill labels with the 'whiteout' option enabled printing correctly.
    The whiteout on some of the labels become transparent, with the rest being whiteout correctly which looks messy.
    This only seems to happen when you apply a transparency to the Cut Fill map (even 1%) which I use often to show the PDF beneath
    Running TBC v5.9 I believe
    Thanks
    Jake Gibbs
  • 2.  RE: Cut Fill labels not printing correctly - transparency issue
    Posted 05-02-2024 15:38
    Anyone?
    Jake Gibbs
  • 3.  RE: Cut Fill labels not printing correctly - transparency issue
    Posted 05-03-2024 08:41
    Can you share your project....?
    Erik Petersen
